I have a yfz it wont crank over to start but will just buzz when trying to be started i have left the key on one time and battery died but it charged up after a hr of riding! But the other day i was out doin donuts and out of nowhere my bike turn of with a nasty sound like something broke internal! I have been told that i could of dropped a valve and broke the head! Or crankshaft when out the bike has to has atleast 80+ hrs ridden pretty hard no mods dead stock!! Dont know the problem
I would start by both checking your battery voltage as well as taking the side engine plugs (by the shifter) out and try turning it with a ratchet to see if it will turn over. If it doesn't it could be something in the engine, starter or it could be the infamous clutch basket explosion.
Can u shift to neutral? IF NOT PRAY TO DADDY 2020 U GOT THE EXTENDED WARRANTY.
I read somewhere even out of warranty yamaha will repair it out of warranty for clutch basket in "good faith" but you have to gamble like 300 buks of labor to have stealership assess damage.
Play it safe. Take out clutch cover. And inspect everything BEHIND OEM BASKET.
Ei isaac any updates??
