You going to pull your after market stuff off first ? .., I would
My 2017 YFZ450r sounds like the rod bearing blew. bike has 20 hrs on it if that. For performance the bike has fmf 4.1 full exhaust and a vortex tuner map5- 6,6,7. I've changed the oil 3x already. air filter before every ride. oil is saturated and over filled with gas. Was full to the brim when I checked the oil. so fuel is leaking into the engine somehow. I noticed that after sitting over night the bike would take 5 or 6 seconds to start vs starting up instantly like when it was new or after riding it. It would only blow black smoke when you first started it. After riding if I let it sit and idle and revved it. no black smoke....something is leading me to think I have a stuck open fuel injector or a leaky one when the bike is sitting... or have a hole in my piston. anyone have any ideas or experience a similar issue before?
Add in a few oil changes as well for best results. If I build an engine, I warm it up, soon as its up to temperature, change the oil and filter. Make a few runs from just off idle to rev limiter, letting it engine brake all the way back down, do this at 1/4, 1/2, 3/4 and then full throttle. So a few at quarter throttle, few at half, etc. After that's done, I change the oil and filter again.So my understanding is that the preffered non manufacturer say is to warm up the quad real good and then let her have it dont baby it and put a good load on the engine for like 20 minutes and let it cool down and repeat a few times. Done.
Correcto mundo?
Those instructions are incorrect......How many people do you want me to produce who have had their bikes dynoed? Like I said I am one of the most experiencedMy map 9 is a high compression map and my map 1 is the power map for stock motor with the 3 mods
people with the Vortex on this site...I just spoke with Leonard Duncan and was told ALL Vortex maps for 09-17 are identical......Map 9, 5, 6, 6 was the recommended starting point for a three mod bike at any altitude on pump gas....Make sure your TPS has been set properly before you tune.....Ctown208 has extensive knowledge on the Vortex software if you're curious....
I can't offer you info on your knocking problems unless I could see it in person.
Per the manufacturer heat cycles and varrying engine rpm should of been the way you ran it for the first few hours for break in....I can post a video if you would like if you don't believe me....
Sounds like the rest of your maintenance is good!
Hint see the left upper corner....lots of posts and I've been on Central for a fairly long time.......
It ended up being the gear off the clutch basket. Very common issue with the 2017s but is covered under warranty. The fuel in the oil issue was solved with new rings. Mine apparently had faulty rings from the factory too.Anyone hear whatever happen with the OP issue?
