Just bought a 2014 yfz 450r it has full dasa exhaust system with the power commander V and K&N air filter But when I’m going to turn slow in first gear the four wheeler wants to cut off but only when I’m going slow if I’m on the gas it rides good. I was just wondering if it’s the power commander Has anybody else had this problem
Yes I have the power commander as well and had the same issue go into your map and add +2 to ur rpm range 0-3500 and 0 -15% columns if that doesn't fix slowely add more fuel in that range
Appreciate the info but I can’t seem to get it right idk what the problem is but I just ordered the vortex ECU hopefully that’ll fix it
