So I have a 2012 r and having some problems. The bike will start up and run for 20 secs then shut down and won’t start back up. the bike is all stock except a GYTR slip on. FI is new to me sense I grew up racing Honda Trx 250rs
1. replaced the battery
2. New ECU
3. New injector
4. Ran the valves all was good.
5. Replaced the fuel pump also with a new factory one.
Also it not giving me any code.
Any ideas on where to go from here before I take it to the local ( Dick) dealer.
Ever ran good with this setup?
If you turn the key off and back on does it start? Have you checked your tip over sensor?
