Once I start riding and go to get on it a bit it will bog out, probably need to clean the carb, but where is the air/fuel mixture screw at on this carb? I found the idle screw, not the same thing right?
Are you running the OEM 2012 carb? I believe they are a different carb than the older YFZ450 models and don't work as well. If it's in the budget switch to the older carbs, it's a big upgrade.
It's the oem Mikuni carb. I found it after I took out the carb and cleaned it, just ordered a new screw for it so it's easier to adjust. Having a problem where once I get on the throttle a bit when riding it'll start skipping/popping.
