I am selling my fully built 2010 YFZ450X that is built to race in woodsracing / harescrambles. Contact me with a contact number and we can discuss the quad in detail. $5200 Valencia PA. Parts list:
2010 YFZ45X XC BUILT
MXP BUILT MOTOR (HIGH COMPRESSION PISTON/STOCK BORE)
VORTEX WITH BALANCE RACING MAPS
REKLUSE CLUTCH (OEM FIBERS WITH 6 HOURS)
HOUSER SLI CAST A ARMS (JUST REBUILT)
CECCO BRACKET
EXIT SHOCKS (FRESH SERVICE)
HOUSER PRO BOUNCE NERF BARS
HOUSER +1 STEERING STEM
GREASEABLE UPPER STEERING STEM BEARING
FASST FLEXX BARS (REBUILT 6 HOURS AGO)
ASV SHORTY LEVERS
POWERMADD HAND GUARDS (FULL WRAPS)
PRECISION PRO STEERING STABILIZER (6 HOURS )
DIRT WORKS LINK (6 HOURS)
HEAVY DUTY TIE RODS
NEW OEM BRAKE PADS (FRONT AND REAR)
STEEL BRAIDED FRONT BRAKE LINES
HONDA THUMB THROTTLE
NEW THROTTLE AND CLUTCH CABLE
OVERSIZED RADIATOR FAN (2 HOURS)
CV4 BLUE RADIATOR HOSES
IMS OVERSIZED GAS TANK (SCREW CAP)
AFTERMARKET SEAT COVER
UNI AIR FILTER
DUAL ALUMINUM SPROCKET GUARD
STEEL ROTOR SKID
PLASTIC BELLY SKID PLATE
PRM REAR WIDE CONTROL GRAB BAR
PRO ARMOUR FRONT BUMPER
HIPER DUAL REAR BEADLOCKS
HIPER FRONT SINGLE BEADLOCKS
TIREBALLS ALL FOUR TIRES (SERVICED 6 HOURS AGO)
GBC XC MASTER FRONT/REAR TIRES (8 HOURS)
D.I.D. GOLD O RING CHAIN
T.M. SLIDE AND GUIDE CHAIN SLIDE
BALLANCE RACING CASE SAVER
FMF FULL EXHAUST
FMF POWERBOMB HEADER
The frame is welded where the vin number is and near the left foot peg bolt holes. I have a low hour frame being shipped to me now and I will either sell the quad as is along with the used frame or switch the frames out and keep the welded frame and part it out. Contact me with any questions and I can send more pics if you provide me an email or phone number.
I will try to sell the quad outright and if I cant, I will consider parting it out.
CECCO BRACKET
ASV SHORTY LEVERS
HEAVY DUTY TIE RODS
UNI AIR FILTER
STEEL ROTOR SKID
FMF FULL EXHAUST
