1 - 20 of 21 Posts
Moderator
Unfortunately my dream quad is up for sale. Buying a new home and it has to go.
2010 YFZ450X fully built from the ground up, everything powder coated, Ported 478cc CP 13:75.1 piston, CP billet rod, Crankworks balanced and welded crankshaft, Barkers performance full stainless exhaust system with titanium heat wrap, Fox float evo front shocks, BNR Custom rear shock, Precision steering dampener, Antigravity lithium battery with easy access charging plug-in, CTEK Lithium battery charger, Anthony Pennachia Custom wire harness, Spal 400 CFM high flow radiator, KTM throttle body, Works connection hour meter, IMS 3.8 gallon fuel tank with billet cap, Cyrca pro bend hand guards, Maier white plastics, Houser racing XC long travel a-arms, Houser pro bounce Nerf bars, hiper tech3 beadlocks , maxxis razr 2 6-ply tires, RP race XC intake system, vortex ecu, magura ydraulic clutch, Fourwerx carbon fiber radiator shrouds, fourwerx custom seat cover, stainless steel fasteners on entire build, Teixeira tech sprocket guard and swing arm skid plate, CRF 1/2" Poly full frame skid plate, EZ Drain oil fittings for fast, clean oil changes, and much much more....Best parts money can buy. Must see show quad! Engine fully broke in on Lucas Conventional motorcycle oil and then switched over to fully synthetic 15W-50 Blud Racing Oil. Clean and clear Ohio title. Have all receipts of parts installed. Over $20,000 invested. 2.2 hours on build. Dyno tuned for 110 Plus Renegade Race fuel. Build took almost a year to complete. Have all original parts as well. Buyer will receive all photos of the complete build, receipt booklet, original plastics, tub of brand new spare parts, brand new spare engine case purchased from Yamaha, 8 Quarts of Blud Racing oil, 3 oil Filters, USB Jump drive full of complete build start to finish photos. Serious Inquires only. May include a 55 Gallon drum of Renegade Pro 110+ with the quad. Contact me for details or any questions $14,000 OBO . Will post photos shortly. Some photos can be found on my 2010 YFZ450X Custom Build post here on the forums.
Moderator
Moderator
Damn, you just finished building it! Good luck with selling, if I had the room I would be all over it. You might have better luck (but a bit more frustration) parting it out.
Moderator
Discussion Starter #12
We found a house so gotta get it gone wife’s orders lol. Yes it’s a smoking deal. Can’t buy a new one for that let alone what I have in this quad.
What weight is the suspension setup for and
Troy Ohio. Those GT500’s are slick
It’s a 2013 but should make around 1000rwhp.
What weight is the suspension setup for on the quad? May I ask what it made on the Dyno?
1 - 20 of 21 Posts
