1 - 1 of 1 Posts
I did a fresh oil change and only had 2 trail rides on it and it shut off on me, the oil smelled like gas and it had gas coming from the exhaust when trying to crank. I replaced the injector and changed the oil and it started right up... My only concern is when I took the oil out it was 3/4 of a quart low, this quad doe snot smoke or else I would know it is the rings. I just want to know if the stuck injector I replaced caused me to burn a little oil on that ride?
1 - 1 of 1 Posts
