Hey guys been years since I've been active but now I'm back needing help. My engine light came on and the code I got is 46. Voltage not normal is basically what it means. Battery shows 13.5v with a meter on pos and neg engine off. But shows 18-19 running!!! I think this is what's causing my error. How can I fix this? ohh and I already inspected all the connections and wires with the plastics off. Even switched back to my stock ECU same result. Quad runs perfect. Just super high volts. I removed my headlights awhile back and just left them unplugged. Don't know if that matters but I rode like that for awhile with no light. The day I got the light I had just removed my clutch switch and tied the wires together because o got a new lever that didn't accept the switch. Could this be causing me a problem? Thanks in advanced
I'd see if you have a nasty or disconnected ground wire. I wouldn't run the bike with that high of an output as it will cook everything. I would also test your rectifier and your stator once your are sure you have not bad or cooked wires.
