Just did a complete rebuild on a 09 yfz450r. Turn the key on and I have full power. I hit the starter button and it will roll over once and then kills everything until i release the button. Not sure if it's a ground issue or what to check first.
Only thing I can think is the ground. When I wired it back up the only wires I was unsure about was the nutural switch. And there is a 2nd wire coming from the negative post on the battery but idk where it goes?
Theres a ground on the back of the engine. I believe there are 2. I cant remember
