Hey I bought a 2009 Yfz450r Like 2 weeks ago, the first day I got it it was working perfectly it starter right up and it was driving perfectly(was riding on snow) i stopped driving it for a little and like 15 min later I went to start it and it didn’t wanted to start. I realized I had a bad starter relay fuse, I fix that fuse and put new battery, then it starter right up no problem... I let my brother drive it and I got it back with a broken valve gasket.I fixed that, then found out the battery wasn’t charging because I had a bad stator (when I was changing the stator it had broken bolts inside from the starter clutch), i put a brand new stator and brand new start clutch bolt . So the problem I am having now it is that it crank and crank but it won’t start and it backfire while is cranking it take a lot for cranks for it to start,so I have to connect a battery charger because the battery die after so many cranks, it will start after so many cranks and it will also idle good and drive good, if I shut it off it will start again but everytime I leave it sitting for like a day or few hours it does the same thing(crank for ever until it will start)
(Also if I hit the throttle quick it will kind of bog a little)
Can someone please help me I been having nightmares since I got this quad. ;(
