I have a 09 YFZR that I have a owned since it was pretty much new. Currently has 48 hours on it with a meter.
All upgrades like the exhaust programmer, stabilizer, suspension and new piston/cylinder at 40 hours.
Full Walsh set up, arms and camber bracket,and stem. Third gen fox shocks front and rear set up for 180 pound rider. Precision stabilizer, Pro flow adapter in dual stage filter, MSD programmable fuel and ignition, rpm axle, Rear headlocks. GYTR nerfs/propegs, and belly skid. Rental bars, honda throttle, easy pull levers, Full Dr. D exhaust. Just had Brand new factory piston,and cylinder installed as preventive maintenance at 40 hours. I believe keeping motors stock for the most part although I did get a brand-new 2006 yfz cam installed also for better bottom end.
located in 22406 va
