i have Yamaha YFZ450R Year 2009 fuel injection.. ( ) im having little issue when i try to turn it on it will turn off by it self when i hit the throttle it shut off i think it might be electrical. EVERYTHING is stock only mod i have is a exhaust slip on .. so i installed
  1. NEW Fuel pump
  2. Brand NEW air filter
  3. Brand NEW throttle body fuel injection. .
4 Brand new BOOT
5. premium 93 gas
6. tip over sensor glue mod
7. change spark plug x2 have good spark
i check the timing it on point. i check the compression is around 120 psi
they are all OEM parts
