Hi, Guys.
I am about to do my yfz450 rear wheel bearings as there is a bit of play there. I was wondering if anyone can tell me if there is 4 bearings in the hub and if someone might have the sizes for bearings, seals and orings. I would rather get them locally. Thanks guys.
Front wheels use wheel bearings. Rear wheels bolt up to a hub that is bolted to the axle and no bearings there. The axle uses bearings inside the swing arm.
You should in your free time look up the OEM parts diagram for your quad. At any yamaha dealer website clik on OEM PARTS.
Discussion Starter #4
Thank you, I did look it up in yamahapart.com, there is 4 bearings in the rear axle, that is what I meant, would anyone have sizes for them bearings and seals. Thanks
