I have a yfz 480 with cams, also sparks racing exhaust, and bike was running fine did and oil and filter change and then started the bike everything was good, I check the engine oil level and it was good. Then next day I started it for 5 mins then smoke started coming out from the radiator on cap side, notice it was low so I got some extra coolant and Tap it off and had it running with the cap off and it was cycling like it should, but little smoke started coming after running while from inside the radiator and around the camp side. Idk what to do
