Answering any of the 4 questions would help
-New 2006 Wiring Harness.
1. What connects to the Brown and Yellow connector pictured?
2. The Yellow w/ Blue strip & Black wired connector reaches (about 18" long connector) pictured. They go together with (1.)? Just feel weird that the wiring harness would connect back to itself so I assume I'm wrong.
3.This doesn't have a resistor assembly as I guess it was removed from previous owner. What color wires connects to the resistor assembly?
4. What color wires connects the radiator?
Automotive tire Hood Automotive lighting Motor vehicle Automotive design
Bicycle handlebar Motor vehicle Automotive design Electrician Bicycle
So that is the tors system connection for the carb, hate it absolutely terrible bypass it 100%, now the connector that you got I don’t see any wires looping back to it so is it built into it or what? But yeah bypassing or joining them together on the body harness side of it pretty much does something to trick it, can’t remember exactly what but it helps with throttle response, did this yesterday actually on my cousins quad because it would not idle or rev when it would idle, after I joined that it was so rev happy
Got the ATV working
1.) I think it's the brake (even though my brake lights are not working currently.)
2.) This is for the resistor assembly
3.) Resistor is removed per RMstator instructions.
4.) ?
