1 - 17 of 17 Posts
getting you guys up to date on my project i started a few weeks ago.
I have already done a big bore kit using an Athena 98mm cylinder, CP 98mm piston, ported the head, converted to kickstart, Boyesen supercooler, Oil mod, CHR oversized radiator, CV4 radiator hoses. Previous mods i have done are FCI, DASA classic exhaust. I have taken my frame to get powder coated and will be taking another trip to the powdercoat shop with wheel hubs, exhaust canister, NEW +4 swingarm, engine mounts etc. Will update with more photos along the way.
Update
Just sent off my +4 swingarm, front bumper, engine mount, sprocket and brake hubs as well as the wheel hubs to powdercoat. I picked up my Frame from the powder coat shop and installed the engine and radiator. i still have to remove 2 more gears behind the flywheel(im waiting for the puller) and i also have to adjust the timing (cam mod) before i can button up the engine. next update will be after i rebuild my carb and install intake, exhaust and carb. Also i just sent off my wiring harness to 38 Motorsport to gut the harness for a kick starter with no battery.
Discussion Starter #4
*UPDATE
I rebuilt my carb and was going to install the #35 leak jet in the bowl but it wasn't happy so it looks like I'm ordering a R&D racing power bowl 2 since a float bowl is $150-ish anyways.
Discussion Starter #5
Alot to throw into this next update
93425
i have removed all the electric start gears and one way clutch on the flywheel. Ive heard this is equivalent to a -6oz flywheel.
93426
93427
I went ahead and did the cam mod. Didn’t feel like doing it immediately when i rebuilt the top end so im doing it now.
93428
93429
I cut my rear fenders since this is a duner only, and also I would need to cut the fenders for the kickstart arm anyways.
93431
I repacked and installed my cerakoted Dasa Exhaust (4-bolt) exhaust and mocked up my tyson racing +4 swingarm.
93432
I mocked up my New houser racing +2 steering stem and anti vibe clamp. Just waiting on pro taper bar and grip as well as the pivot works steering stem rebuild.
93433
93434
Discussion Starter #12
installed my protaper bars and pivot works steering stem rebuild.
93453
93452
Got my new wheel/tire setup
93450
Got my long travel Alba a-arms and guess what! One of the lower arms doesnt fit. Its a 16th of an inch to wide. So hopefully they will send me a new one.
93451
Discussion Starter #13
Getting to small detail stuff while waiting on the last shipment of parts. Dasa exhaust decal, route the clutch and throttle cable, install my galfer brake lines, install ASV levers
93455
93456
Discussion Starter #14
No more bluetooth swingarm! i got it all installed and the brakes bled. I pressed in all the bearings and a-arms are in. just waiting on my elka shocks to arrive. I also decided to take the stock throttle and brake caps to my mill and take off all the ugly lettering.
93557
93558
93559
93556
1 - 17 of 17 Posts
