So I just got an 04 yfz and I just want to get to know what to expect maintenance wise and just overall tips and tricks about these machines because this is my first one (I'm 16)
Thanks
Thanks
The quad looks very nice i have a 05 of the same color and my tio has a 04 same color too.
Already got the airbox lid off with and hmf slip onThey're pretty reliable quads and you should do the cam mod and zip tip mod. And take the lid off the air box and take the spark arrestor out and learn how to rejet the carb.
ThanksThe quad looks very nice i have a 05 of the same color and my tio has a 04 same color too.
Cool! I'll keep that in mindZip tie mod is completely safe. If you keep up with your maintenance then you should be fine. IMO I would still do the oil upgrade anyways just to be on the safe side. Rather not take the risk and save my engine
How often shoukd I change oil and what oil should I use?Zip tie mod is completely safe. If you keep up with your maintenance then you should be fine. IMO I would still do the oil upgrade anyways just to be on the safe side. Rather not take the risk and save my engine
I would do the oil mod because it can probarly save your engine one day. And i change my oil every two ride and i use 10w-40 racing 4t mobile 1 oil.[/Q
Cool, thanks .I would do the oil mod because it can probarly save your engine one day. And i change my oil every two ride and i use 10w-40 racing 4t mobile 1 oil.
He has heel guards and nerf bars tooI suggest heel guards.
The HMF Slip-on, airbox lid removed, and the cam mod should put you in the 45p, 168mj, 4th clip on the needle range.
Oil update is a must you will granade that engine. I bought a 04 last year cheap for that reason. Spend the $$$ to get it done. I also have an 05 since new that was one of the upgrade I did. Still running. I use jtatv.com. fast turnaround time.Already got the airbox lid off with and hmf slip on
And I thought the ziptie mod was hard on the engine?
The cam mod is something I'll do eventually once I build the confidence to do so lol
What do you think about the oil update because I'm getting mixed feelings of weather you need it or not because my uncle has an 04 as well that he races that he's never had a problem?
Thanks
Hey lil man,no matter what you do now,you'll know what best to do only when you used the quad for a year or 2So I just got an 04 yfz and I just want to get to know what to expect maintenance wise and just overall tips and tricks about these machines because this is my first one (I'm 16)
Thanks
For sure I'm already learning things just from messing around with it 🤙Hey lil man,no matter what you do now,you'll know what best to do only when you used the quad for a year or 2
Hey man! This is a late reply but nice quad! How do you like your quad so far with these past few months that have passed by. Summer is here and it's time to rip through some more tires.So I just got an 04 yfz and I just want to get to know what to expect maintenance wise and just overall tips and tricks about these machines because this is my first one (I'm 16)
Thanks
Thanks!Hey man! This is a late reply but nice quad! How do you like your quad so far with these past few months that have passed by. Summer is here and it's time to rip through some more tires.
