1 Bottom end needs rod bearing still spins $400
1 bottom end needs a rod $400
Carburetor. 140.00
Frame 150
Subframe. 100.00
Stock a arms. 150.00
rear hubs. $40
Full bore white Plastics. 250.00
Rear axle. 60.00
Gas tank. 30
Wiring harness. 50.00
Cdi. 50.00
Light run switch. 35.00
Key and switch. 30
Seat 70
Rear swing arm. 60
Rear bearing carrier. 55.00
Rear brake caliper. 60.00
Rear master cylinder. 30
Front master cylinder. 50
Clutch perch w lever. 20
Front hubs & spindles. 100
Front brake calipers. 60
Brand new dynatek rev box $150
Complete clutch $150
Good cylinder and piston $150
Good head needs 2 valves $450
Good Ported head $500
Cams ??
Engine covers ??
Full Stock exhaust $100
2 header pipes $30
Other misc ask if you need
Contact by text if your in canada 12042661276 , anywhere email is fastest [email protected] or by pm
