new plug, rejetted it with 168 main, 45 p, needle set 4th clip, 2 screws out on a/f screw it was running great for about two hours then it started the stumbling at around 4000 rpms and I put the oem cdi box and it seems to be a little better but not 100%. Could the dynatek cdi box go bad like that?
If the different CDI box made a difference, try wiggling wires while revved at 4k rpm and see if the stumble goes away. Also check all your connections(grounds, connectors and terminals).
The new cdi box makes it feel like a Honda vtec kick in at 3500 rpms lol any ideas?
