OK..
Looking for some insight from you guys that have allready replaced the stock bars with aftermarket that sit higher (1/2" on the ones I have).
I am installing the trail-tech X-bars with their YFZ clamp and this will raise the bar up 1/2 over stock.
1- How do you lengthen the front brake line? replace it ? or will it extend long enough for this amount of rise?
2- How do you re-route the clutch cable to gain added length for the additional height?
Any other hints to getting a taller set up on and dealing with all the cables/ lines???
