I recently bought a 2009 YFZ 450R with a acrb conversion. Ever since I got it, I can't seem to get the idle right. I did buy a tach/hourmeter that wraps around the coil, so I could see numbers and not guess at it. I know the service manual says the Idle should be right around 2,000, but when I adjust the idle it's either too low or too high. It also seems as if the idle hangs a little bit. I sure hope someone can help. This is really starting to bug me.
Thanks
It could be something sticking in the throttle cable or in the carb that's keeping it hanging.
My advice: start sourcing parts to put it back to EFI or part it out and get either a factory carb or EFI, whichever you prefer.
I owned a GT Thunder carb converted '09 for a long time. Eventually parted an otherwise solid quad over a wiring harness. Sounds crazy but there's no support there anymore with Laz gone.
I kept it going for awhile, rebuilt the carb, fixing the wiring harness (over and over), etc. It was a great quad in it's day, but the technology is old and the support isn't there. When my harness was finally complete junk, I couldn't get anybody to make one. With GT Thunder out of business, I couldn't get a diagram to figure out how the harness was modified.
I do know that you need 2 harnesses to make one. An '08 carb and '09 EFI. I tell you this because this could be part of your problem (if not now, it's coming). That harness has been in that bike for 10 years, by contrast, when I raced one, I replaced a harness every year.
Probably not what you want to hear and maybe yours is different, just giving you my experience. PM me if you need anything. I fought that quad for years.
Sent from my LM-V450 using Tapatalk
Discussion Starter #4
Thanks for the replies. I'm leaning toward a carb issue here, as I'm pretty sure the throttle cable is ok. But for 10 bucks I'll replace it for peace of mind. And I already have an 05 YFZ, so I'm pretty familiar with carbs. This thing is just really bugging me, since I cant get it figured out. I'm going to order a rebuild kit for the carb. I really think it's a slide issue, possibly the o-ring for the slide plate. It also has an FCI intake, and a Dasa full exhaust, and a 13:1 comp piston (stock bore), so I was wondering if I could get some jetting recommendations.
The carb was setup like this when I got it:
Main: 168
Pilot: 52
NDSR needle: 3rd clip position
Fuel Screw: 2 1/4 turns out
My elevation is 427', any more help would be appreciated, my 05 has never given me as big of a headache as this thing.
I've got FCR carb parts left over from that thing. You're welcome to them. I think I have a complete carb and assorted parts from others. You can have them for the shipping, I'm all EFI.
