I have an 07 yfz 450 I bought recently and I’m having electric problems they said the battery was draining so I did some research and saw that it was most likely the rectifier so I got a new one and the previous owners had rigged something together as if they took one off of something else because the wire is a different gauge and it looks completely different but everything seems to be working fine besides they had two of the yellow wires coming out of the stator and rigged it up somehow and it would start instantly on a fresh charge and run good but now I don’t know where the wires are supposed to go because of how they had them hooked up any help would be appreciated
94582
94583
94584
94585
You replaced rectifier and it all works fine now?
The rectifier works and the battery holds a charge but we can’t figure out where those two yellow wires went and we’re thinking it’s not getting any spark
Is that a universal one or an OEM one?
