Did you drain the carb?
I did drain the carb...didn't clean it though.Did you drain the carb?[/b]
Gas is on. Is it possible to change the plug w/o pulling the tank off? Should I pull the carb off or just pull the bowl and jets and clean with cleaner?As Sidewinder said and make sure the Gas is on, replace spark plug. Carb might need a cleaning.[/b]
No, you will need to pull the tank off. Thats no big deal. You could start by pulling the bowl and go from there. Do you know if it is getting fuel ? Spark ?Gas is on. Is it possible to change the plug w/o pulling the tank off? Should I pull the carb off or just pull the bowl and jets and clean with cleaner?[/b]
It's getting fuel since the incoming fuel line was full as well as the bowl. As for the spark, I haven't pulled the plug yet. I'll do that this evening.No, you will need to pull the tank off. Thats no big deal. You could start by pulling the bowl and go from there. Do you know if it is getting fuel ? Spark ?[/b]
