I've got a 07 YFZ with an 04 motor in it. It got a full rebuild over the summer, and has had starting problems since. It's on its 2nd starter and 2nd battery. It's got a Trail Tech High Output stator in it, I checked the exhaust cam decompression pin, and that's fine. And I retorqued both cams just to be sure.
The only way it will start is if you put a battery charger on it. Once it's been running for 10-20 minutes to get warm, it'll start right up on the first crank. It will not start if it's cold without a charger on it.
When you try to start it without a charger it will crank over once, then wait a second, then crank over once and wait, and so on slowly increasing the wait between cranks.
When cold, the battery is at 12.74VDC +/- and drops to about 6-8VDC when cranking. But when it's hot, it only drops to 11VDC when cranking.
Any ideas on what next? If I wasn't still paying for it, I'd trade it off for a R...:bawl
