1 - 9 of 9 Posts
i have an 06 yfz, that the rod went through the cases. so i ordered 07 cases and an 07 oil pump. i have heard different things about the oil mod. do i have to do it or not??
QUOTE (Sidewinder @ Mar 2 2009, 02:42 PM) index.php?act=findpost&pid=752958
lol, no, you do not, will not, have the oil mod. You still need the squirter which is part of the right crankcase cover.[/b]
Correct... Check JTatv (site sponsor) and they can help you out with the rest.
QUOTE (#38 YFZ450 @ Mar 2 2009, 07:12 PM) index.php?act=findpost&pid=753043
SO ILL HAVE TO DO THE 04-06 OIL MOD THEN.[/b]
yes, if you want the mod done, you will have to get your right side cover machined, get the squirter and put it all together.
the clutch case cover is the part that is modded (unless you do the mod yourself as described in the sticky topic)
you already have it apart, just send the case cover to j&t, let him machine it, you already have the oil pump, all you need is the squirter then. its not that big of a deal, and he will give you a great price since its not the whole kit.
1 - 9 of 9 Posts
