I have a 05 yfz450 and had a bunch of charging problems with it. These older models didn’t come with a resonator from the factory ad the newer ones did I have found out how to cheat it and make it work so you don’t have to run head lights full blast. 1. You want to go get a 2010 yfz450 resonator from eBay or get oem. 2. You need to find a yellow with red wire going to the head light relay or you can tap in after were the stator plugs in at. 3 once you found that one side goes in the the resonator and the other wire will go to a good ground now the charging with be balanced out and not need head lights at all.
