QUOTE (yammy rider @ Mar 22 2009, 04:39 PM) index.php?act=findpost&pid=760798
You can pull the head off and measure how far the piston travels in the cylinder. If it is 62 mm then it has the older crank. If it is 63.4mm then it is the newer crank. As far as the rods the longer rod is the 05 and the shorter one is the 06.
