ok i a buddy of mine has an 05 yfz
the motor takes about 20 kicks to finally start
after it starts and runs and gets warm and then put it into gear and get on the gas to move it just dies
we have had 5 differnet people try to ride it (and all of us race) but no one can move the quad
it will run with the clutch pulled in but then when you let it out it just bogs down and dies
any one have any idea about this problem
we re jetted the quad new gas new oil spark plug
Check and make sure that the TORS wire is intact at the throttle housing and at the wire harness under the hood. If you eliminated it at one point check fr a loose connection.
