1 - 1 of 1 Posts
So I recently picked up an 04 yfz450, it will crank if i jump the starter relay and it has a distributor pulse, i put a new battery, new starter relay, new starter cut off relay and a new handle bar switch on it and nothing, someone already bypassed the throttle position switch and I bypassed the clutch switch, the neutral switch has ground at the connector under the hood, i was also told it has a new rectifier, it will run with if i jump the starter relay but as soon as i pull the screwdriver off it dies, any help would be appreciated, as far as my guess im thinking cdi box but ive put enough parts on this thing already
1 - 1 of 1 Posts
